I Need to conect throught isa sever to remote host.First i use cisco vpn client to establish connection and all its ok , the problem came with pcanywhere (10 ) I cant connect with the remote host, i tried it with secure nat and firewall client and i cant ping the remote host, without firewall there is not problem to connect .
THANKS BUT.
The VPN connection is established, but there is no traffic possible through the tunnel with securenat client and firewall and I cant ping to the remote host.
did you check out the status screen on the VPN client? Once the VPN tunnel is established, you should see 'Transparent Tunneling: Active' and 'Tunnel Port: UDP 4500'.
OK, that seems to be a somewhat older Cisco NAT-T implementation. Therefore, you should have a protocol rule allowing UDP port 10000 send/receive. I would create this one in addition to the other two listed in my article. Also, keep in mind you should first test with the Firewall client disabled.
the next thing to do is running the 'ipconfig /all' and 'route print' command on the VPN client with *and* without the VPN connection established. You should see some added routes and the TCP/IP properties of the VPN adapter when the VPN connection is establised.
Now, all depends on how the VPN administrator has configured the VPN client, but check out that the network ID you want to reach through the VPN tunnel is different from the network ID used on your internal network.
