i can block user through mac address
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> i can block user through mac address Page: [1]
i can block user through mac address - 18.Nov.2004 2:39:00 PM
kalwar
when i block user through block rules then user change its ip address and get again access. how can block user at mac address through isa server
thanks
RE: i can block user through mac address - 18.Nov.2004 4:05:00 PM
Ara.A
You have to have them either use static ip address or use the firewall client and create policy based on users
(in reply to kalwar)
RE: i can block user through mac address - 19.Nov.2004 6:12:00 AM
AHIT
As Ara suggests, it's not possible to block via MAC address.
That being said, evn if ISA WAS capable of blocking by MAC, it's almost childs-paly to change the MAC address of almost every NIC on the market these days...
Block at the userID level or via static IP's if the users always uses the same box.
RE: i can block user through mac address - 19.Nov.2004 11:28:00 AM
sysadm
We can restrict users from changing the ip address of the system. This can be implemented using POLEDIT where we can disable the Network Control Panel itself. so they cant change the ip of the client systems. This is possible in os like Win9x,Wint,Win2k.,
RE: i can block user through mac address - 23.Nov.2004 8:46:00 AM
kalwar
any other way for restrict users from changing the ip address of the system, can't open network control not a correct way.
RE: i can block user through mac address - 25.Nov.2004 9:24:00 PM
syed_atif
Hi
Install isa in DOMAIN CONTROLLER then u can easly block users MAC address even users change his IP he will not able to use INET
in my point of view this is the simple way to block MAC address
bye
RE: i can block user through mac address - 29.Jul.2005 4:51:00 PM
helpforisa
Atif Bhai, What to do after installing ISA in the domain. ???
Can you tell briefly???
Regards
Asim
RE: i can block user through mac address - 16.Aug.2005 6:22:00 PM
Salam!
Why dont you use sygate firewall which has ability to control your users via mac plus it has scheduler to allow or block based on a schedule
RE: i can block user through mac address - 18.Aug.2005 2:46:00 AM
aqib khan
u can restrict users via MAC by using Sygate Personal Firewall 5.0.
this the only solution of blocking Mac addresses.
RE: i can block user through mac address - 23.Oct.2005 6:54:00 PM
strongbatman
hi all...
this is my firat reply in this beutifull forum ..
u can block any user via mac address its a possible way just use a programe named .. NETCUT .. and its easy to use ..
