ISA with 3 NIC and ONLY 192.168.xxx.xxx
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> ISA with 3 NIC and ONLY 192.168.xxx.xxx Page: [1]
ISA with 3 NIC and ONLY 192.168.xxx.xxx - 22.Oct.2004 12:50:00 PM
Hi there,
I'd like to setup one single ISA Server 2000 (SP1) on a machine with 3 NICs.
NIC 1: -> Default Gateway (Router to DSL Connection)
NIC 2: -> No Default Gateway
NIC for partner network
NIC 3: -> No Default Gateway
My Local Network (in LAT)
My problem is:
If I write the 192.168.0.xxx network into my LAT, routing between the subnets works fine, but I can not use filters anymore.
If I remove the 192.168.0.xxx network out of the LAT table, inbound routing (192.168.0.xxx to 192.168.100.xxx) will not work anymore.
I've tried several packet filters, but I could not get it to work.
Any suggestions from you experts ??
RE: ISA with 3 NIC and ONLY 192.168.xxx.xxx - 23.Oct.2004 12:46:00 PM
to better understand the trihomed DMZ setup in ISA server 2000, check out:
- http://www.isaserver.org/tutorials/ISA_Server_DMZ_Scenarios.html
- http://support.microsoft.com/default.aspx?scid=%2Fservicedesks%2Fwebcasts%2Fwc110801%2Fwcblurb110801%2Easp
- http://www.amazon.com/exec/obidos/ASIN/1931836663/isaserver
The key point is that the DMZ should not be a LAT member. In that way the DMZ interface will be considered as another 'external' interface. So, the normal protocol and site&content rules apply for outbound access, and the normal publishing rules apply for inbound access.
If you want a real multinetworking feature then you should take a serious look at ISA server 2004.
(in reply to DerTom)
