please i need a pro assistance.
please i need a pro assistance. - 28.Jun.2005 3:10:00 PM
Zabarbar
i'll simplify the scenario; External - DMZ - Internal
i'm publishing a mail server (outlook web access) and i configured the router to nat clients to the OWA, in monitoring i get 'connection initiated', destination: the nat address but the client actually fail to web access, any idea if it's a router issue or an ISA rule?
help is very much appreciated, thanks.
RE: please i need a pro assistance. - 28.Jun.2005 3:25:00 PM
Hi Zabarbar,
to find out which one is the culprit, place a workstation on the DMZ and test first the OWA publishing rule from there.
HTH, Stefaan
RE: please i need a pro assistance. - 28.Jun.2005 4:35:00 PM
Zabarbar
from the DMZ it's working because i use the server's actual IP (http://172.16.1.30/exchange) but from the external side the client is using using a nate'ed public address (http://192.125.16.80/exchange). in the ISA monitoring window i can see the address 192.125.16.80 with connection initiated but the client fail to connect..??
RE: please i need a pro assistance. - 28.Jun.2005 5:19:00 PM
steavg
Hi zabarbar,
Can you post us your publishing rule.
Stefan
RE: please i need a pro assistance. - 29.Jun.2005 3:27:00 AM
Zabarbar
this is it:
ISA Server with 3 NICs Private: 192.168.1.201/24 DMZ: 172.16.1.20/24 Public: 10.0.1.3/24 GW: 10.0.1.1 (router)
DMZ has the Mail server (Exchange Front-end) with the IP address 172.16.1.30/24 GW: 172.16.1.20
first i created network rules between the dmz and the external network and the dmz and internal network, the network relationship is Route not NAT.
these are the rules i'm using: 1- Access rule allowing http traffic from external to dmz web server. 2- Access rule to allow http traffic from external to external (worked in my scenario. 3- Publish Mail Server (Front-end Exchange) which has nic ip 172.16.1.30 and using address 10.0.0.45 as it's public name
action: allow from: anywhere to: 172.16.1.30 traffic: http listeners - networks i checked external and internal. public name: request for the following websites; 10.0.0.45
now from an external network workstation (10.0.0.22) i type in Internet Explorer the following:
i get the user name a password prompt and that tells me the access rules are working.
when i type http://10.0.0.45/exchange i get nothing (error)
when i check the monitoring/logging i can see: destination 10.0.0.45 - initiated connection - external to external (rule) - client 10.0.0.22
then a connection failed and closed connection notes appear after that.
i know it's confusing but i believe someone here might know what exactly is the matter and how to solve it, so i ask; please guys if you can help me shoot this out please do.
thanks.
RE: please i need a pro assistance. - 29.Jun.2005 6:51:00 AM
Hi Zabarbar,
you should never use IP addresses in your web publishing rules but FQDN's instead.
HTH, Stefaan
RE: please i need a pro assistance. - 29.Jun.2005 11:36:00 AM
steavg
Hi Zarbarbar,
As Stefaan already mentioned, use FQDN. Place them in your host file.
Greetings
Stefan
