plz help me
All Forums >> [ISA Server 2000 General] >> General >> plz help me Page: [1]
plz help me - 21.Nov.2004 1:31:00 PM
zziaullah
hello its zia anyone can solve my problem
i have network of 25 computers on network i have two lan cards but only one is using system confirguration of lan card is
ip address: 192.168.0.1
subnet mask: 255.255.255.0
default gateway:192.168.3.160
preferred DNS server: 213.42.20.20
Alternate DNS server: 195.229.241.222
the ip address of these DNS servers are given from my ISP.... so plz tell me how ISA server 2000 will configure with these settings
[ November 21, 2004, 01:42 PM: Message edited by: zziaullah ]
RE: plz help me - 21.Nov.2004 5:12:00 PM
w0rst12
You need 2 LAN cards to configure ISA server.
1. For Internal IP Routing
2. For external WAN routing
LAN settings
IP. 192.168.1.0 ( Or what ever you choose)
mask 255.255.255.0
Gateway 192.168.1.0
DNS 192.168.1.0
WAN settings
IP . 213.*.*.* << Your STATIC ip
MASK 255.255.255.* << Your ISP's MASK
Gateway 213.*.*.* Your ISP's Gateway
DNS 213.*.*.* Your ISP's DNS
(in reply to zziaullah)
RE: plz help me - 22.Nov.2004 6:16:00 AM
zziaullah
WAN settings
in this setting what will be the IP 213.*.*.* [any ip of this class]? or anyother?
RE: plz help me - 22.Nov.2004 7:18:00 AM
w0rst12
213. wat ever is your own IP , for example my ip is 203.89.154.204 allocated by my ISP or the service provider's Ip they have assigned me and better ask them their Gate way and DNS as well
RE: plz help me - 22.Nov.2004 7:46:00 AM
zziaullah
ok i have configured 2nd lan card
so now the system configuration are:
Internal IP Setting:
preferred DNS server: 192.168.0.1
External WAN Settings:
ip address: 213.42.1.20
but its still not working plz tell me what wrong with it? and my ISP have just given me the ip of DNS servers others ip's are not allocated from ISP
RE: plz help me - 22.Nov.2004 1:01:00 PM
isa_dude
why your gateway on the external interface is the same as the internal gateway
your default gateway is causing the problem
RE: plz help me - 22.Nov.2004 1:11:00 PM
zziaullah
then plz tell me what will be the solution?
RE: plz help me - 22.Nov.2004 3:02:00 PM
dos-netres
You configured the default gateway of you internal LAN on the WAN interface card.
The default gateway on your WAN should be in the same network as your IP address.
So the 3 first octets are :213.42.1.x
Just fill in the x value (this is provided by your ISP)
Good luck
Regards
Koen
RE: plz help me - 22.Nov.2004 3:54:00 PM
zziaullah
no my dear there is no ip allocating from my ISP i m getting internet from only the DNS servers (213.42.20.20 & 195.229.241.222)
Its my system configuration
IP Address: 192.168.0.1
Subnet Mask: 255.255.255.0
Default Gateway:192.168.3.160
Preferred DNS server: 213.42.20.20
The IP Adresses of DNS Server (213.42.20.20 & 195.229.241.222) are given from my ISP.
And my web proxy server is set to "proxy1.emirates.net.ae port:8080"
So plz can anyone tell me how i can share this connection using ISA Server 2000?
I have installed ISA2K but internet is not sharing and there is error the gateway could not retrieve requeted page. Is there any special setting for DNS server IP addresses
Can anyone help me plz its urgent ?
RE: plz help me - 22.Nov.2004 4:02:00 PM
eleon
You cannot put a gateway in two adapters ...this is going to drive your ISA nuts. Put the Gateway in your external NIC and left the Gateway space in the internal NIC empty.
Because all your users are in the same network you donŠt need a Gateway in your internal NIC. If some day in the future your network becomes into a routed one, you will have to add those networks manually to your ISA using the command:
route add 192.168.x.0 Mask 255.255.255.0 192.168.0.1 Metric 1 -p
The -p parameter will make the change persistent and it wonŠt be deleted in the next server reboot.
I suggest you to use a private IP address in your external network because if you put someday another firewall in front of your ISA ...you will have a BIG headache trying to make it all work [Razz] .
Eleon
RE: plz help me - 22.Nov.2004 4:29:00 PM
zziaullah
still same problem
if u will tell me in detail setting of 2nd nic card then it will better
RE: plz help me - 23.Nov.2004 3:04:00 PM
zziaullah
Anyone can plz help me
