My computer has ISA 2006 installed on it, when i'm surfing to the web (http/s) with it. it takes the request (e.g. www.cnn.com sport = 1111) and bridge the request from inside the isa server meaning that the isa is starting a new request to www.cnn.com in a new port.
my problem is that i need to keep the original port of the request.
Yep. But it is not "bridging" that is a Layer2 function performed by Switched,...it is "proxying",...that is what proxying is, that's what it does, that is even definition of "to proxy" implies,..."to do something on behalf of something else".
my problem is that i need to keep the original port of the request. IS IT POSSIBLE??
There is no situation where I can think of a reason for what you say you need to actually be true. I think you misunderstand what you need or are using an incorrect approach to a solution,..or both.
