problems publishing a library externally over ssl
problems publishing a library externally over ssl - 2.Oct.2008 7:43:45 AM
lordasb
Ok trying to work from basics on this. I have got the following to work inside the school The internal auto login versions below http://scr01/oliver/gateway/gateway.exe?application=Oliver&displayform=frame http://oliver.thomasdeaconacademy.peterborough.sch.uk/oliver/gateway/gateway.exe?application=Oliver&displayform=frame now the external works at https://scr01/oliverexternal/gateway/gateway.exe?application=Oliver&displayform=frame https://oliver.thomasdeaconacademy.peterborough.sch.uk/oliverexternal/gateway/gateway.exe?application=Oliver&displayform=frame from the wi01 server we get the following https://10.48.0.16/oliverexternal/gateway/gateway.exe?application=Oliver&displayform=frame shows the following There is a problem with this website's security certificate. The security certificate presented by this website was not issued by a trusted certificate authority. The security certificate presented by this website was issued for a different website's address. Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server. We recommend that you close this webpage and do not continue to this website. Click here to close this webpage. Continue to this website (not recommended). More information · If you arrived at this page by clicking a link, check the website address in the address bar to be sure that it is the address you were expecting. · When going to a website with an address such as https://example.com, try adding the 'www' to the address, https://www.example.com. · If you choose to ignore this error and continue, do not enter private information into the website. For more information, see "Certificate Errors" in Internet Explorer Help. When you click the link – to go though Technical Information (for support personnel) Error Code: 403 Forbidden. The server denied the specified Uniform Resource Locator (URL). Contact the server administrator. (12202) https://oliver.thomasdeaconacademy.peterborough.sch.uk/oliverexternal/gateway/gateway.exe?application=Oliver&displayform=frame shows the following This problem can be caused by a variety of issues, including: Internet connectivity has been lost. The website is temporarily unavailable. The Domain Name Server (DNS) is not reachable. The Domain Name Server (DNS) does not have a listing for the website's domain. If this is an HTTPS (secure) address, click tools, click Internet Options, click Advanced, and check to be sure the SSL and TLS protocols are enabled under the security section. Now i looked on the wi01 server this is looking to pcc mis for dns Microsoft Windows [Version 5.2.3790] (C) Copyright 1985-2003 Microsoft Corp. C:\Documents and Settings\Administrator>ipconfig Windows IP Configuration Ethernet adapter Teamed NIC: Connection-specific DNS Suffix . : IP Address. . . . . . . . . . . . : 10.48.0.12 Subnet Mask . . . . . . . . . . . : 255.255.254.0 Default Gateway . . . . . . . . . : 10.48.0.1 C:\Documents and Settings\Administrator>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : WI01 Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter Teamed NIC: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : HP Network Team #1 Physical Address. . . . . . . . . : 00-19-BB-35-FA-62 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 10.48.0.12 Subnet Mask . . . . . . . . . . . : 255.255.254.0 Default Gateway . . . . . . . . . : 10.48.0.1 DNS Servers . . . . . . . . . . . : 193.61.85.3 193.61.85.4 C:\Documents and Settings\Administrator> Which should resolve the oliver.tda.pb.sch.uk to 193.61.85.246, which in turn is asa’ed to 10.48.0.16 via nat, so it hits the .16 address of the isa01 server. Now i can see traffic hitting the .16 of isa from perimeter network and from my home address of 81.187.168.52 in the logging when doing Please see attached notepad file for details of connections from wi01 to 10.48.0.16, the first 2 lines show when you hit enter on the address bar in IE, i don’t know why its saying about alan as a rule. The next few lines are where it trys to offer a connection to the oliver but fails offing the default rule as the one blocking it. The lissener is setup on port 10.48.0.16 asking for no login details so it should be requested by the oliver system, all this is over a ssl link. Do you have any ideas? Hope i have given you enough info to understand what i am trying to do. With thanks andy below is the contents of the notepad Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Authentication Server Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:20 42612 0 0 0 0x0 ERROR_SUCCESS 0x0 0x0 Firewall - 25/09/2008 11:52:20 10.48.0.16 443 ALaN 80,443 Initiated Connection 10.48.0.12 Perimeter Network Local Host - - 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:20 42612 0 500 1129 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN 0x0 0x0 Firewall - 25/09/2008 11:52:20 10.48.0.16 443 ALaN 80,443 Closed Connection 10.48.0.12 Perimeter Network Local Host - - 0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.2; .NET CLR 1.1.4322; .NET CLR 2.0.50727) Yes Reverse Proxy ISA01 10.48.0.16 TCP - - - Req ID: 0da0cd08; Compression: client=Yes, server=No, compress rate=0% decompress rate=0% - - - 25/09/2008 10:52:31 0 1 2264 303 12202 The ISA Server denied the specified Uniform Resource Locator (URL). 0x0 0x0 Web Proxy Filter 25/09/2008 11:52:31 10.48.0.16 443 https Denied Connection Default rule 10.48.0.12 anonymous Perimeter Network GET http://10.48.0.16/oliverexternal 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:32 42621 0 0 0 0x0 ERROR_SUCCESS 0x0 0x0 Firewall - 25/09/2008 11:52:32 10.48.0.16 443 ALaN 80,443 Initiated Connection 10.48.0.12 Perimeter Network Local Host - - 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:32 42621 0 393 290 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN 0x0 0x0 Firewall - 25/09/2008 11:52:32 10.48.0.16 443 ALaN 80,443 Closed Connection 10.48.0.12 Perimeter Network Local Host - - 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:32 42622 0 0 0 0x0 ERROR_SUCCESS 0x0 0x0 Firewall - 25/09/2008 11:52:32 10.48.0.16 443 ALaN 80,443 Initiated Connection 10.48.0.12 Perimeter Network Local Host - - 10.48.0.12 ISA01 - TCP - - 25/09/2008 10:52:32 42622 0 806 2695 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN 0x0 0x0 Firewall - 25/09/2008 11:52:32 10.48.0.16 443 ALaN 80,443 Closed Connection 10.48.0.12 Perimeter Network Local Host - - what i cant work out is that the https is not getting carried over from outside to inside. any advice thanks andy
RE: problems publishing a library externally over ssl - 2.Oct.2008 10:51:32 AM
lordasb
Original Client IP Client Agent Authenticated Client Service Server Name Referring Server Destination Host Name Transport MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Result Code HTTP Status Code Cache Information Error Information Log Record Type Authentication Server Log Time Destination IP Destination Port Protocol Action Rule Client IP Client Username Source Network Destination Network HTTP Method URL 0.0.0.0 Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.2; .NET CLR 1.1.4322) Yes Reverse Proxy ISA01 http://oliver.thomasdeaconacademy.peterborough.sch.uk/CookieAuth.dll?GetLogon?curl=Z2F&reason=0&formdir=3 oliver.thomasdeaconacademy.peterborough.sch.uk TCP - - - Req ID: 0eb43168; Compression: client=Yes, server=No, compress rate=0% decompress rate=0% ; FBA cookie: exists=yes, valid=yes, updated=no, logged off=no, client type=public, user activity=yes - - - 02/10/2008 14:04:10 0 1 2264 477 12202 The ISA Server denied the specified Uniform Resource Locator (URL). 0x0 0x0 Web Proxy Filter 02/10/2008 15:04:10 10.48.0.16 80 http Denied Connection Default rule 81.187.168.50 tda\aba External GET http://oliver.thomasdeaconacademy.peterborough.sch.uk/
