proxy settings
All Forums >> [ISA Server 2004 Cache] >> Web Proxy client >> proxy settings Page: [1]
proxy settings - 5.Sep.2007 6:45:29 AM
walter81
We currently have a firewall we're going to replace in the not-so-very-far future. This firewall is also our proxy-server for internet access.
I'm setting up an ISA 2004 server to provide internet access. This works fine accept I'm having some trouble with a few internal websites.
We've got 3 plants (connected via a WAN): A, B and C
at all 3 plants we've got an application that's only accessable via httpS://x.x.x.x:444, we also have another application at plant A (where the ISA server is located) wich is assessible via http://x.x.x.x:8080
At the ISA server I've
  •  added port 444 to the SSL port list
  •  enabled webproxy for the internal network wich has
    • all network ranges from the 3 plants in the addresses tab
    • web proxy enabled
    • "bypass proxy for webservers in this network" enabled
    • "bypass proxy for computers specified in the domains tab" enabled
  • enabled webproxy for the local host network
  • added port 444 to the protocol list and enabled it for inbound connections.
  • created a new firewall rule for HTTP(S), FTP and port444 trafic from the internal to the external network
  • enabled auto discovery for the internal network
I've set my connection settings to "automatic configuration file" with location "http://isaserver/wpad.dat" at my PC in plant A and a test PC in plant B & C.
And this is the result:
* internet works just fine
* at plant A I can only access the https:444-site for plant A, at the other 2 plants I can access them all 3.
At plant A I receive this error for the other 2 https:444-sites:
Error Code: 502 Proxy Error. The ISA Server denied the specified Uniform Resource Locator (URL). (12202)
* the http:8080 site works only in plant A (were that server is located), at the other 2 plants I receive the same error (Error Code: 502 Proxy Error. The ISA Server denied the specified Uniform Resource Locator (URL). (12202))
what am I  doing wrong?
< Message edited by walter81 -- 5.Sep.2007 6:49:18 AM >
RE: proxy settings - 27.Nov.2007 10:12:16 AM
abqtech
Make sure you have SP2 or SP3 installed on your ISA Server.  In the ISA MMC goto:
Configuration -> Networks -> Internal -> Web Browser
And add/modify your internal domains to include a trailing /*
i.e. assuming you want all web proxy requests to bypass ISA for your entire domain.  You should add domain.com in the Web Browser tab as:
*.domain.com/*
See if that resolves the problem.
(in reply to walter81)
