routing question
All Forums >> [ISA Server 2004 Firewall] >> Network Infrastructure >> routing question Page: [1]
routing question - 18.Nov.2010 10:42:33 AM
mrcosmo
Dear mr/miss,
We have the situation below:
1 webserver with ip: 171.0.0.2(dmz) and with external 99.99.99.99(example)
I made a new publish rule and made everything point to the specific adapter the ipadress of 99.99.99.99 is within our external ehternet card which has other extern ip adresses.
when i try to go to the website i get an certificate error
what could be the problem ?
RE: routing question - 19.Jul.2012 10:56:07 AM
01blackerado
Do you get the Cert error if you hit the web page locally on the physical box? This isnt an ISA issue, just to be clear. This is an SSL issue with the way youre accessing the website. There are two ways to go about this.
1. Web Publishing rule. From=External IP associated with the web page in question, To=Web Server, Protocol=HTTPS Server
2. Create a www listener, associate it to port 443, install the cert on the ISA machine, import the cert to the web rule.
But like i said earlier, this isnt an ISA issue, its an issue with the URL used to access the site and its direct correlation with the SSL Cert you've created
(in reply to mrcosmo)
