same network with two interfaces
All Forums >> [ISA 2006 Firewall] >> Network Infrastructure >> same network with two interfaces Page: [1]
same network with two interfaces - 30.Apr.2008 5:14:05 AM
HSeffers
Hello,
I need to prepare an ISA enviroment with the following network situation:
Interface 1: Internet
Interface 2: Internal network with these adresses
142.87.0.4, 142.87.0.6-142.87.255.255, 142.114.0.0-142.114.255.255, 142.115.0.0-142.115.255.255
Interface 3: other local network with these adresses: 142.1.0.0-142.86.255.255, 142.87.0.1-142.87.0.3, 142.88.0.0-142.113.255.255, 142.116.0.0-142.255.255.255
On the third interface ISA will get the 142.87.0.3 as ip adress. Behind this interface is another router with the ip 142.87.0.1. Behind this router is the rest of the 142.x network, except 142.87.x.x, 142.114.x.x and 142.115.x.x
Now I worry that the routing between the two internal networks wont work. I wont be able to test it before friday.
In fact we need to set the ISA firewall between these two networks.
Will this solution work? Do I have a major wrong thinking of this solution?
How to solve best, if this does nto work?
It would be great to get some input here. As well I am working with ISA Server for a few years now, I never had such a situation.
Thanks in advance for any input here
Holger
< Message edited by HSeffers -- 30.Apr.2008 5:17:01 AM >
RE: same network with two interfaces - 30.Apr.2008 5:52:02 PM
pwindell
You have to have a good solid network design before you introduce ISA into it.
You do not appear to have that.
IP Segments should not be larger than 250-300 Hosts (like 255.255.255.0),...not 64,770 (255.255.0.0) hosts per segment as you have.  Now you can supernet subnets together across backbones between routers but there is no indication you are doing that.
Phillip Windell
www.wandtv.com
(in reply to HSeffers)
RE: same network with two interfaces - 26.May2008 5:49:21 AM
HSeffers
Hello,
thanks for your answer.
But the network design is done by the VPN provider.
Each location gets its own network. Thing is, the implementation we have in this case is not our standard. Usually there is no ISA server, as all use a centralized internet gateway.
Anyway, I managed to make this work, as followed:
I added a static route for one host: 142.87.0.1 255.255.255.255 142.87.0.3
Then I added routes for all networks behind the router 142.87.0.1
I added one route to the rest of the network 142.87.0.0 pointing to the local network.
I added these networks to the networks within ISA server too, as well as the range 142.87.0.1-142.87.0.3to the DMZ network of ISA.
I just needed to add as static routes the two networks behind the local network 142.114.0.0 and 142.115.0.0 in the Routing&Ras  console.
It didn't work in the command prompt.
Finally all is working.
HSeffers
(in reply to pwindell)
