secured socket connection port 58400
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> secured socket connection port 58400 Page: [1]
secured socket connection port 58400 - 26.Jul.2007 9:34:38 PM
olddog
One of my clients running a SBS 2003 Premium server needs a connection to one of his venders on port 58400.  All the internal clients need to use the port. I have tried several different setting changes and none have worked.  I opened the filter, added protocol, etc.. I am wondering that you cannot set an ssl connection to a different port.
To access the web site the vender sent a email with a URL in it like below.
https://sales25.companyname.ws:58400/psp/fstrg/***/?cmd
Can anyone give me a hand.
RE: secured socket connection port 58400 - 26.Jul.2007 10:16:49 PM
ferrix
Sounds like you need to authorize that port as an ssl tunnel port.  Check out isatools.org I believe there is a useful script to help with that.
(in reply to olddog)
RE: secured socket connection port 58400 - 27.Jul.2007 2:29:11 AM
Status: online
read this article to know how to extend the ssl tunnel port range : http://www.isaserver.org/articles/2004tunnelportrange.html
and u can get the GUI tool from here : http://isatools.org/tools/ISAtrpe.zip
and the script from here : http://isatools.org/tools/isa_tpr.js
Tarek
RE: secured socket connection port 58400 - 27.Jul.2007 4:41:44 PM
olddog
Thanks elmajdal,
         But will it work with SBS 2003 Premium, the ISA server is 2000.
I read the readme it  states that the isatools are for ISA server 2004.
Thanks Again
OldDog
ORIGINAL: elmajdal
Tarek
(in reply to elmajdal)
RE: secured socket connection port 58400 - 27.Jul.2007 4:57:15 PM
Status: online
The article is for ISA 2004, but the tools are also avialable under the ISA 2000  Tools, so they should work
check here : http://isatools.org/tools.asp?Context=ISA2000
Tarek
RE: secured socket connection port 58400 - 29.Jul.2007 12:03:30 PM
olddog
The ISA tools will not run.  I am getting an error.
"com object eith clsid {XXX gives an ID #} is eather not valid or not registered."
It also will not show the 2 ports that are shown in the help.
Olddog
RE: secured socket connection port 58400 - 29.Jul.2007 12:15:18 PM
Status: online
have u ran the script ?
RE: secured socket connection port 58400 - 29.Jul.2007 9:46:57 PM
olddog
Yes
Ran the Script.  Didn't work.  Uninstalled software ran script installed software. didn't work installed then ran script still didn't work.
Do I need to re boot server or  stop and restart a service.  Remember I am using SBS 2003 premium that has ISA 2000 in the package.  And I am using the gui version of the software.  I will try just the script.
Thanks for the help so far.
Olddog
< Message edited by olddog -- 29.Jul.2007 11:50:27 PM >
RE: secured socket connection port 58400 - 30.Jul.2007 12:21:57 AM
olddog
The script worked .
 They are connecting to the website.  I'll let you know how it is doing when they get in tomorrow and can fully test the connection.
  They also wanted a CISCO VPN connection to the head office.  I found several how  to(s)  on Microsoft TechNet and other help forums, but none of them worked.
Thank you very much,  Elmajdal
I be ordering your books.
RE: secured socket connection port 58400 - 30.Jul.2007 12:47:06 PM
Status: online
Glad it worked and thanks for the follow up.
My books , i dont have any yet , but i do have some articles
so for the SSL port your are done, have u accomplished the CISCO VPN or not yet ?
