voip setting Script for Vonage vt1000v
All Forums >> [ISA Server 2000 Firewall] >> SecureNAT Client >> voip setting Script for Vonage vt1000v Page: [1]
voip setting Script for Vonage vt1000v - 31.Dec.2003 4:24:00 AM
smarisetty
HI,
Having done some experiments, have the following VBScript working for me. The attached script makes all the necessary settings. I have only opened up UDP 10000 and 11600 only from the 10-20K range. I snooped the network traffic with NetMon and saw that only these two UDP's were used for audio. The other ports 5060-5063, 69 and 123 were enabled as well.
To run the script, copy the following into a file with notepad.exe and name it something like vt1000vadd.vbs. From the Windows:Start run this file and it will setup the ports as needed. If you want to undo the changes, copy the second script into a file named vt1000vdel.vbs. Run this from windows and it will undo. Hope this solves problems for many people.
----------- copy from here into vt1000vadd.vbs--------
Sub vt1000vadd
'Enabling UDP ports for Vonage vt1000v ATA
' UDP In: {69,123,5060,5061,5062,5063,10000,11600}
' UDP Out: {69,123,5060,5061,5062,5063,10000,11600}
Const prxInbound = 0
Const prxOutbound = 1
Const prxSpecifiedProtocol = 1
Const prxFwSrvSvc = 0
Const prxAllServices = 2
Const prxTCP = 0
Const prxUDP = 1
'Initialize the Internal/External IP
Const IntIp="192.168.16.54"
Const ExtIp="63.198.196.228"
Const UdpRangeCnt=7
Dim objFPC, objArray, objSPR, ObjPD, ojbPR, MyProtDef, MyProt, myCnt
Dim UdpIn(7), UdpOut(7)
'Ports for RTP media streams-audio: Primary
UdpIn(0)=10000
UdpOut(0)=10000
UdpIn(1)=11600
UdpOut(1)=11600
' Ports for Handshaking - ring control
UdpIn(2)=5060
UdpOut(2)=5060
UdpIn(3)=5061
UdpOut(3)=5061
UdpIn(4)=5062
UdpOut(4)=5062
UdpIn(5)=5063
UdpOut(5)=5063
' Ports time
UdpIn(6)=123
UdpOut(6)=123
' Ports for tftp
UdpIn(7)=69
UdpOut(7)=69
'Create the root object
Set objFPC = CreateObject ("FPC.Root")
'Make sure it's current data
objFPC.Refresh
'Find where we live
Set objArray = objFPC.Arrays.GetContainingArray
'Create a new protocol rule now to cover all UDP outbound protocol defs
Set objPR=objArray.ArrayPolicy.ProtocolRules.Add("zVoipUdpEnable")
objPR.Description = "Enable UDP for vt1000v VOIP"
objPR.Enabled=True
objPR.Action=fpcActionAllow
objPR.ProtocolSelectionMethod = prxSpecifiedProtocol
objPR.SetAppliesAlways
'Create a protocol definitions, Server Publishing Rule
For myCnt=0 to UdpRangeCnt Step 1
'Inbound UDP
Set objPD = objArray.PolicyElements.ProtocolDefinitions.AddUdp("zUdpIn"&UdpIn(myCnt), prxInbound, UdpIn(myCnt))
objPD.Description = "UDP"&UdpIn(myCnt)&" forwarding to vt1000v"
'Save the changes
objPD.Save
'Outbound UDP
Set objPD = objArray.PolicyElements.ProtocolDefinitions.AddUdp("zzUdpOut"&UdpOut(myCnt), prxOutbound, UdpOut(myCnt))
objPD.Description = "Outbound UDP "&UdpOut(myCnt)&" enabling for vt1000v"
'Save the changes
ObjPD.Save
'Publishing Rule to forward the Inbound UDP port
Set objSPR = objArray.Publishing.ServerPublishingRules.Add("zUdpFwd"&UdpIn(myCnt))
'Configure Server Publishing rule
objSPR.Description = "UDP"&UdpIn(myCnt) &" forwarding to vt1000v"
objSPR.InternalIp = IntIp
objSPR.ExternalIp = ExtIp
objSPR.SetProtocol("zUdpIn"&UdpIn(myCnt))
objSPR.Save
' add all UdpOut's to the Procotol Policy rule
objPR.SpecifiedProtocols.Add("zzUdpOut"&UdpOut(myCnt))
objPR.Save
NEXT
objSPR.Refresh
objPD.Refresh
objPR.Refresh
objFPC.Refresh
objArray.SendRestartNotification(prxFwSrvSvc)
' Finally done doing it all
MsgBox ("done add - restarting server")
' release the objects
Set objFPC = Nothing
Set objPD=Nothing
Set objSPR=Nothing
Set objArray=Nothing
Set objPR=Nothing
End Sub
vt1000vadd
----------- copy til here ----------------------------------
------------ copy from here into vt1000vdel.vbs--------
Sub vt1000vdel
'Deleting UDP ports for Vonage vt1000v ATA
Const prxTCP = 0
Const prxUDP = 1
Const UdpRangeCnt=7
UdpIn(0)=10000
UdpOut(0)=10000
UdpIn(1)=11600
UdpOut(1)=11600
UdpIn(2)=5060
UdpOut(2)=5060
UdpIn(3)=5061
UdpOut(3)=5061
UdpIn(4)=5062
UdpOut(4)=5062
UdpIn(5)=5063
UdpOut(5)=5063
' Ports time
UdpIn(6)=123
UdpOut(6)=123
' Ports for tftp
UdpIn(7)=69
UdpOut(7)=69
objFPC.Refresh
'Find where we live
'Delete Access Policy for Vt1000v
objArray.ArrayPolicy.ProtocolRules.Remove("zVoipUdpEnable")
objPR.Save
' **** done delete of only one protocol rule
'Delete Server Publishing Rules
objArray.Publishing.ServerPublishingRules.Remove("zUdpFwd"&UdpIn(myCnt))
objSPR.Save
'**** done delete publishing rules
'Delete a protocol definitions for Inbound
objArray.PolicyElements.ProtocolDefinitions.Remove("zUdpIn"&UdpIn(myCnt))
objPD.Save
'Delete a protocol definitions for Outbound
objArray.PolicyElements.ProtocolDefinitions.Remove("zzUdpOut"&UdpOut(myCnt))
ObjPD.Save
' **** done delete protocol definitions
NEXT
MsgBox ("done delete - restarting firewall service")
objFPC.Refresh
Set objPD=Nothing
Set objSPR=Nothing
Set objPR=Nothing
End Sub
vt1000vdel
------------- copy til here ---------------------------------
RE: voip setting Script for Vonage vt1000v - 31.Dec.2003 4:33:00 AM
smarisetty
Here is the url to an updated VBScript:
http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=8;t=000586
(in reply to smarisetty)
RE: voip setting Script for Vonage vt1000v - 31.Dec.2003 7:32:00 AM
smarisetty
In all my excitement, I forgot to add the following notes to the above:
Change the Internal/External IP address as per your system needs.
In the DHCP Configuration of ISA, reserve a fixed IP address for vt1000v (tied to its mac address) as ex: 192.168.16.54.
Also, change the script to replace the External IP value to that of your public IP (don't use mine).
DISCLAIMER: Use at your own risk and is provided as a helper guide only. Feel free to modify/change/distribute it at will.
[Razz]
RE: voip setting Script for Vonage vt1000v - 22.Jan.2004 12:54:00 AM
How would a person go about modifying this script for an Enterprise Policy? Thanks!
RE: voip setting Script for Vonage vt1000v - 16.Jun.2004 9:52:00 PM
hagb13
I can not make it work. Can you give more instructions?
Thank you in advance! [Smile]
RE: voip setting Script for Vonage vt1000v - 15.Oct.2004 3:17:00 AM
cmpenney
How would you setup the script if the External interface is DHCPed?
RE: voip setting Script for Vonage vt1000v - 14.Jun.2005 2:55:00 PM
cybersmith
I realize this is an older post, but I want to understand why it was setup to create a different protocol definition and server publishing rule for each port?
Was there a problem with setting up a single protocol (well, two if you do one for inbound and one for outbound) with ALL of the designated protocols?? If this was a problem, why?
