web cam
All Forums >> [ISA Server 2000 General] >> H.323 Gatekeeper >> web cam Page: [1]
web cam - 28.Jun.2004 5:39:00 PM
zahid
sir i am using isa server for at least 30 computers some clients needs web cam cahting.how can i enable them web cam option so that they will use web cam .please elobrate how and where to open the ports please elobrate
zahid
dubai
RE: web cam - 4.Jul.2004 8:30:00 PM
Hi Zahid,
Are they using H.323 and the users you want to call also behind an H.323 gatekeeper?
(in reply to zahid)
RE: web cam - 7.Jul.2004 11:30:00 AM
amjad220
Aslam-0-Alakum Zahid
You need to create the following protocol definitons (under Policy Elements):
1. Yahoo! Voice #1
TCP
Port 5001
Outbound
2. Yahoo! Voice #2
TCP
Port 5000
Outbound
3. Yahoo! Voice UDP
UDP
Port 5000
Receive Send
4. Yahoo! WebCam 1
TCP
Port 5100
Outbound
5. Yahoo Messenger Chat
TCP
Port 5050
Outbound
6. Yahoo Voice UDP 2
UDP
Port 5000
Send Receive
7. Yahoo Webcam 2
UDP
Port 5050
Receive
8. Yahoo Webcam 3
UDP
Port 5050
Send
9. Yahoo Voice UDP 3
UDP
Port 5001
Send Receive
10.Yahoo Voice UDP 4
UDP
Port 5001
Send
11. Yahoo Voice UDP 5
UDP
Port 5001
Receive
12. Yahoo Voice UDP 6
UDP
Port 5001
Receive Send
After you create these you need to add a protocol rule for them in Access Policy. It should work. Dont forget to install Firewall client in your workstation and connect Yahoo Messenger with NO PROXY.
For MSN Download a script from http://www.isatools.org/msnim.zip
and follow the instruction from
For eyeball:
Step 1. Enable Eyeball Chat to work with static ports. To do so download v2.2 registry patch to your desktop, locate the file and double-click it to install.
Step 2. Open the following ports in your firewall
- UDP ports 5700, 5701 and 5702 and
- TCP ports 5500, 5501 and 5515.
Eyeball Chat should then work correctly.
(in reply to zahid)
RE: web cam - 15.Mar.2005 12:31:00 AM
reyricana
Hi!
How about if i dont like to used firewall client. im using proxy for a lan & by pass proxy IE option lan setting for my client. is it posible that the webcam comes out?
(in reply to zahid)
