web publishing: destination sets not working?
All Forums >> [ISA Server 2000 Firewall] >> General >> web publishing: destination sets not working? Page: [1]
web publishing: destination sets not working? - 10.Jan.2001 8:15:00 PM
brianp
In ISA, I published 2 web sites (each using a separate external ip address) . When I attempt to connect from an external client, I always get routed to the web site defined in the 1st publishing rule (based on the order field in mmc).
More info:
I published 2 web sites hosted on the same internal web server (server01). The web server is multi-homed and has 2 web sites bound to each ip address (192.168.1.1, 192.168.1.2). For example web01 is bound to 192.168.1.1 and web02 is bound to 192.168.1.2.
Isa server has 2 external ip addresses bound to the external nic on the server.
I created 2 destinations sets: (1.for each external ip address)
I created 2 web publishing rules: web rule #1 was published using the 1st destination set (using the 1st external ip address), and is set to be redirected to the 1st web server. web rule #2 was published using the 2nd destination set (using the 2nd external ip address) and is set to be redirected to the 2nd server.
When I browse using either of the external ip addresses, I always get redirected to the internal web site (web01) bound to the 1st publishing rule. When I enter the 2nd external ip address, should I get redirected to web02?
ISA config:
Os: win2kas sp1
Isa eval (upgrade from rc1)
Brian
RE: web publishing: destination sets not working? - 23.Jan.2001 10:30:00 AM
Brian,
I had a similar problem , and resolved it by simply setting the 'Computer name' in the destination set to the
actual Host Header/ID of the webpage ie. www.microsoft.com (don't use IP address's) . Once you have
created the destination set, create a publishing rule using that specific destination set and point it towards
the internal web server under the 'Action' tab
Hope this helps
Andrew
(in reply to brianp)
RE: web publishing: destination sets not working? - 23.Jan.2001 10:31:00 AM
andrew
Brian,
I had a similar problem , and resolved it by simply setting the 'Computer name' in the destination set to the actual Host Header/ID of the webpage ie. www.microsoft.com (don't use IP address's) . Once you have created the destination set, create a publishing rule using that specific destination set and point it towards the internal web server under the 'Action' tab
Hope this helps
Andrew
