wpad failed for XP clients
All Forums >> [ISA 2006 General] >> Installation and Planning >> wpad failed for XP clients Page: [1]
wpad failed for XP clients - 9.Mar.2009 11:27:42 AM
BDY
Hi there!
ISA 2006 installed on Windows Server 2003 (workgroup) with two NICs as
Edge Firewall using SOHO DSL connection. DHCP is configured on the same server.
Internal Networks defined as local are as follows.
   10.10.0.0 -10.10.0.255      Internal ISA Interface
192.168.1.0 -192.168.1.255  Connected to DSL Linksys
With manual proxy configured on windows Internet Explore, internet access is ok.
I have enabled Auto discovery on ISA and configured the wpad option on DHCP
but XP clients are not able to access the Internet.
Do I need to configure any internal listner?
Any help is appreciated to resolve this issue.
RE: wpad failed for XP clients - 9.Mar.2009 3:39:04 PM
pwindell
If ISA is publishing the two scipts properly you should be able to do this and see each script in the browser:
http://myisa.addomain/wpad.dat
http://myisa.addomain/wspad.dat
When prompted to save or open,..tell it to open.
You should have published it on port 80. Do no fall prey to some documents that say port 8080.  You do not need to put the port numbers in the above URLs.
The entry in the DHCP's WPAD settings should be
Phillip Windell
(in reply to BDY)
