xp and owa
All Forums >> [ISA Server 2000 General] >> Server Publishing >> xp and owa Page: [1]
xp and owa - 1.Jul.2002 4:42:00 PM
techboy
I have an ISA server setup and have published owa. It has been working fine for sometime now. I recently upgraded my pc to xp and now I can not authenticate to owa. It worked fine under win2k..... has anyone seen this issue before???
RE: xp and owa - 1.Jul.2002 9:34:00 PM
Hi Tech,
Check out:
http://support.microsoft.com/default.aspx?scid=kb;en-us;Q319831
Try SSL and Basic Auth.
(in reply to techboy)
RE: xp and owa - 3.Jul.2002 2:39:00 PM
techboy
Tom,
here is the setup. Isa Server connected in a bastion setup. The isa server is also exchange. Owa is not using a ssl connection. Using win2k i can access owa, using xp i can not authenticate?
RE: xp and owa - 5.Jul.2002 10:28:00 PM
Hi Techboy,
The problem is most likely related to IE 6.0. With IE 6.0, it looks like there's a problem with integrated authenticatiion and OWA. You have to use Basic authentication if you want to use IE 6. I know it sounds weird, and I haven't tested it out myself to confirm if this is indeed a problem or under what circumstances its found, but their recommendation is to use Basic auth and SSL to protect the credentials.
