zip files attachments problems with OWA publishing
zip files attachments problems with OWA publishing - 10.Jun.2004 10:51:00 AM
penrose.l@2college.nl
Hey guys ,
When I try to open a .zip file attachment then I get this error :
Error Code: 500 Internal Server Error. The request is not supported. (50)
We have isolated the problem to being caused by ISA 2004 RC1.
Now what's strange is we tried to rename a .rar file to .zip , posted it , and this file opens without problems.
We also tried renaming an original .zip file to .rar and the file is still blocked , which means it's got something to do with the file scanning mech of ISA 2004.
any one else have this problem ? ( btw : we tried changing every rule in ISA , inclusing HTTP filters etc.. nothing helps.
Kind regards, LExP.
RE: zip files attachments problems with OWA publishing - 10.Jun.2004 3:48:00 PM
Hi Lex,
What happens if you disable the HTTP Security filter on the rule?
Did you make any changes to the filter? How large was the file? How long was the URL?
Thanks! Tom
RE: zip files attachments problems with OWA publishing - 11.Jun.2004 2:25:00 PM
Hi Lex,
I'm using a refresh, but I think I would be hard pressed to replicate your cofig. Do you see this with all zip files, or just this one in particular?
Thanks! Tom
RE: zip files attachments problems with OWA publishing - 18.Jun.2004 2:32:00 AM
Hi Lex,
Its pretty strange, because I download zip files of all sizes all the time through the ISA firewall and never have any problems. It'll be interesting to see if the problem goes away with RTM.
Thanks! Tom
RE: zip files attachments problems with OWA publishing - 2.Dec.2004 7:17:00 PM
kikkof
I know it is late, but I'd like to add a workaroud to this issue. The workaroud is to define the publishing rule using the "Mail server publishing rule" wizard. I first tried to publish our mail server manually (using the "New access rule" wizard), everything worked well but the .zip attachments. Asking the file directly to OWA wasn't a problem but we get a 500 internal error using ISA. The two rules seems to be identical, every tab is set to the same values, I have used the same listener I have defined for the "manual rule".
Kikko
